shut down when charger disconnected
why does my computer shut off when i disconnect the charger and try to go on battery power?
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
@jhb , Joe, It is possible the battery is faulty. Try a reset, disconnect charger and remove battery, press and hold power button for 10 seconds, and leave the laptop for a couple minutes. Then reconnect the battery and charger, and try booting it. You can also check the battery perhaps with a DVOM to see if it is holding much of a charge while it is out. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
My laptop shows the battery is at 100%, but the orange light doesn't come on. Laptop works fine when plugged in, but only green light is on, not the battery charging light.
@Mary Bennett
Hi Mary,
You have just attached a "Comment" to an over 4 year old question.
For a better result try going to this page:
https://www.ifixit.com/Answers
and click on "Ask a Question" on the top right of the screen
and ask a new question stating computer make and model number which will be marked on a label on the underside of the computer. This is very important in order for us to accurately help you.
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,473
