Why is my computer not charging?
My computer is working fine but it's showing that is not charging and the computer is still on, but if i unplug the charger the computer shuts down. I don't know what is going on???
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
First, I would recommend checking if the outlet that you are using is working. Maybe try a different outlet. If that doesn't work I would recommend trying a different charger or charging cable. That might work. If it doesn't, then you may want to consider replacing your battery.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 258
