Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para Whirlpool Washing Machine. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Whirlpool Washing Machine.
How to fix error code F08 or FOB
Washing machine starts up and after 2 seconds it stops and this code came up. Have to reset the washer cause the door locks. Ive tried various different loads and even a empty load but no luck.
Esta é uma boa pergunta?
Pontuação 5
2 comentários
fscr10420 error f08
por Compartilhar
I have had a brand new machine installed Friday the 10th,the very first wash came up F08,have phoned manufacturers and Indesit,,they have booked a appointment for 5 days,this should haven't happened as brand new.
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
jmears83 , You did not state your model #. This is info i had come up with, F08 indicates that the heater is an open circuit. Check the heater wires for dislodged or burnt wires and check the heater for continuity with a meter.
Check the link below for further info. and view the video. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.espares.co.uk/advice/0/3521/w...
Esta resposta foi útil?
Pontuação 2
1 comentário:
hi
me i have replace the heater and the ntc at the same time the cable system is ok but the problem still going...what else i have to do???
por Compartilhar
I have the same problem. Replaced the heater, washer functions normally except for the error at the end of the washing when it shows F08. My brother also had the same issue but his machine was repaired at the shop. Mechanic couldn't figure it out (why it is still showing error) so he reprogrammed control unit just for that…
Pontuação 1
1 comentário:
ok very usefull info but unfortunally here in company nobody knows how to reprogramming ,,,all says to replace the control unit and my friend this costs money ..(for nothing????).
por Compartilhar
Adicionar a sua resposta
jmears83 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 36
Últimos 30 dias: 75
Ao todo: 68,508
