Ir para o conteúdo principal
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
How replace power button
please help how i can repair button phone dont turn on
Esta é uma boa pergunta?
Pontuação 0
2 comentários
I need help to find where to get a new power bottom for Asus Zenfone 2
por
You can get it on Aliexpress.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
@raw771 , Anton, Make sure battery is charged, try a different compatible charger if need be. Use the guide below to disassemble the device so you can disconnect the battery for 5 minutes,then plug back in and check/reseat all the connections to make sure all are connected well. Try and power on phone. Good luck.
Asus ZenFone 2 Motherboard Replacement
Esta resposta foi útil?
Pontuação 2
Unless you have a micro soldering setup, you must either send it in for repair, get a new motherboard, or a new phone. You can, however, keep using your phone as is, just don't ever let the battery die.
Pontuação -1
1 comentário:
Then whats the point of having a MOBILE phone? its anchored to the wall by a charger as (some) home phones are anchored to the wall by a jack.
por
Adicionar a sua resposta
Anton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 3,977
