Ir para o conteúdo principal
Repair information for the Garmin Vivoactive HR smartwatch. Released in February of 2016. Model number: 010-01605-03.
20 Perguntas Visualizar todos
display broken / need replacement display
Hey everyone,
unfortunatly I crashed the display of my Gamin Vivoactive HR.
I called Garmin for a replacement and they told me its about 150€.
Is there any other possibility to replace the display by my own?
Buy the display seperatly anywhere ?
I am thankful for every help
Best regards,
Andreas
Esta é uma boa pergunta?
Pontuação 5
1 comentário
Hey everyone,
Best regards,
Cesare
por
Adicionar um comentário
5 respostas
Pergunta mais útil
Hi Andreas,
I have a used display. Are you still interrested?
Esta resposta foi útil?
Pontuação 2
7 comentários:
Is the used display still available?
por
Yes is still available
por
Hey there, I am also interrested. Could you please tell me if the Display is still available? You can also directly contact me via gerrit.puddig "@" conjin.de. thanks
por
Hi.
May I know ifthe display still available?
por
Leonidos didn't answer me. See my Question above...
por
Exibir mais 2 comentários
I had to open my Vivoactive HR because it wad died, what I saw it was water inside device :(
Now I know that it is no super easy way to open this Garmin.
1st. you have to unglued plastic part where buttons sits
2nd. using this hole (buttons whole) you should gently push screen using something like screw
  • be careful with electric tapes (there are few) it is easy to broken (tear) using only a little force
  • there is only 1 screw on button board
Maybe my photos will help anybody to repair this Garmin.
Pontuação 1
So I have a vivoactive hr and yes a crack screen n unresponsive to touch too. Opened it up( direct from screen) and it wasn’t that hard too, but I really hope they start selling the screen so maybe one day I can replace it.
Pontuação 0
2 comentários:
How did you get the screen off? Trying to get it off without completely destroying the unit.
por
It’s being hold down by adhesive tape so use heat
por
You can buy a display there :
https://www.smitacn.com/lcd-screen-for-g...
Pontuação 0
Good to know for future, but in not much more you can buy used but working device :)
Pontuação 0
Adicionar a sua resposta
Andreas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 4,765
