Ir para o conteúdo principal
The Canon EOS 5D Mark II is a 21.1-megapixel full-frame CMOS digital single-lens reflex (DSLR) camera with video recording capabilities.
How to replace usb port
how to repalce usb port
Esta é uma boa pergunta?
Pontuação 3
1 comentário
Thank you very much, Pfaff, for your kind response. I agree that sending to Technical Service will be the best.
But I'm in a hurry in the middle of a project and no time left.
Will go ahead with your so clear instructions.
Many thanks.
Dick
por
Adicionar um comentário
2 respostas
Pergunta mais útil
@dicktracy ,Dick, This is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a couple links to a tear down guide/vid to get you inside the camera to check the charge port and will also post a link to video showing what is involved in repairing a mini USB attached to the board( not your device, will show what is involved). If not wanting to do the repair yourself have a good camera/computer/cell phone repair shop have a look and estimate repair. I have a feeling the camera shop would tell you to replace the whole motherboard. Good luck.
https://www.youtube.com/watch?v=UOb55J09...
Canon EOS 5D Mark II Front Panel Replacement
https://www.youtube.com/watch?v=XgGkCjNS...
Esta resposta foi útil?
Pontuação 4
1 comentário:
@dicktracy, Dick, Your welcome, good luck with your device and thanks for posting back.
por
I also had this problem, had it quickly repaired by these people:
https://www.fantastecne.com/repairs
Got it done very quickly and also had camera cleaned and serviced
Pontuação 0
2 comentários:
How much did it cost then?
por
How much did they charge?
por
Adicionar a sua resposta
Dick Tracy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 4,563
