Ir para o conteúdo principal
The DigiLand DL1010Q was released late 2014 in Europe. The device uses an Android 5.1 Operating System.
20 Perguntas Visualizar todos
Tablet is behaving weird ,thinking of Virus
Hi,
Tablet is behaving weird. I am thinking of Virus. Not sure what to do. Even doing factory reset also it's not working. Please suggest to proceed further.
Thanks,
KrishnaK.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
i kinda have the same problom but mine is ransom ware, you know the big F>B<I< saying pay five hundred dollars or ill be put in jail that was two months ago I had the same problem with my lg phone and I was able to fix it but i tryed everything to my tablet and nothing HELP!!!!!!
por
Adicionar um comentário
7 respostas
Pergunta mais útil
I know this may be late but I wanted to let you know that all factory tablets even sealed in the box have a Accu weather virus that can’t be removed from the settings page. I confirmed with AVG and Avast mobile antivirus that this app is indeed malware and was installed at the birth of the tablet. when in a attempt to remove the malware through the antivirus software it does not allow you too which couldn’t have made it any clear that it is harmful.
As you have said when it is installed on the device it shows pop up ads which is true but it also has some more harmful effects then just that. When installed it tracks your data, all downloads from google play and even can (and does) install other applications without your constent.
I even noticed apps installed that I would never download in a million years on my Digiland tablet and it was frustrating that I couldn’t find a way to remove the virus!
However I have finally found a solution and it could save ur information from being compromised and sold to advertisers like I explained before and remove the harmful app off of your device. It’s to root it.
Yes yes I know it sounds dangerous and hard and blah blah blah but, it saved my data and my device from being bricked and it allowed me to remove the harmful apps off my device and believe it or not it is quite easy. It took me about 25 minutes (with one click kingo root) and it allowed me to remove the harmful application. And the coolest part is that you can unroot right after you remove the app so you don’t have to worry about having the dangers of the rooted device.
So there you have it , rooting is the only way to remove the app and could save ur information and from your device being bricked so I highly recommend you do it ! ( there is plenty of YouTube videos on how to root a android device if you don’t know how to)
Esta resposta foi útil?
Pontuação 1
1 comentário:
Well I can't hurt to try, I've had nothing but issues and now I get unfortunately Android Services has stopped. So I can't get anywhere so I don't know what to do next but I am going to start looking at YouTube for any info on rooting my device, I may have to hook up to my computer. I'm really not sure because I can't get anywhere as it stands now. But thank you for the information and if I could give you a 10 I would. Thank you so much
por
Scan using something like Avg antivirus
Pontuação 0
I tried almost anything and still the problem. Also said had a storage problem
Pontuação 0
I found the problem you have to flash the rom but if the tablet its china its almos impossible to find rom for it Goodluck
Pontuação 0
When mine started acting this way, I tried to do a factory reset and now it won't let me set up and get into the system at all. The OS is completely messed up. No idea how to fix it. :( So it sits and collects dust on my desk. So aggravating. :( Tara
Pontuação 0
1 comentário:
I have the same problem,
por
What about connecting to a computer and deleting anything suspicious but have a virus software on hand and scan immediately after.
Pontuação 0
y do it not let it go on gest???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
Pontuação 0
Adicionar a sua resposta
KrishnaKKPega123 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,155
