My blade assembly dose not turn
the motor is running but the blade assembly will not turn
Esta é uma boa pergunta?
Pontuação
0
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 155
If you run the motor and turn the tool upside down, or possibly with the tool head pointing down, does it make a grinding noise?
If I had a tool that had a working motor, but wasn't spinning, I would first look at the motor shaft connection to the transmission gears, and transmission gears themselves.
por Geoff Ice
