Ir para o conteúdo principal
Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
Camera on LCD OFF
Iam shooting some photos with my cannon 70d and as my cell phone is connected to camera I left it on. After 30 minutes camera is on but no display on LCD I can't shoot any photo I tried with another battery another card issue is still there can any one help me in this regard....
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
1.) Press the "INFO" button on the back of the camera. Press it repeatedly and it should cycle through the different modes. One of the modes is actually "LCD OFF", so that could be the culprit.
2.) Also make sure that the rubber "eyecup" padding has not slid up 1/4 inch and covered the "display off sensor" that turns the display off when you put your face up to the camera. If that rubber eye pad (or dirt or makeup or your thumb or anything else) is covering the sensor, then the display would turn off thinking you have the camera up to your face.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Dear
I didn't find any display sensor off can you send me any video or like that to identify this part issue is that camera is focusing but on pressing shutter speed no click nothing I think issue is different than this
por
I had dropped mine in sand and had a similar problem with the lcd and playback. The camera still was working, but I couldn’t see anything I took. Kind of like traditional film. Anyway, I gave it a good deep clean and noticed the shutter button had some crud in it. For whatever reason that fixed my problem.
Pontuação 0
Adicionar a sua resposta
Ali Zia será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 5,100
