Ir para o conteúdo principal
Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
20 Perguntas Visualizar todos
Time Capsule not powering on
I've been using this device for about 1 year until one day I found the light blinking amber. The Airport app was reporting the device was overheated. I pulled the plug and waited for it to cool down and when I plugged it back in there was no light at all. All I could hear was the noise of HDD spin up and nothing seemed to work.
It's out of warranty so can't take it to apple.
I cracked it open and found out that the PSU seemed to be functional. I checked the output voltage and it was a solid 12 Volts. But the fan doesn't run at all. I even tried to apply voltage to the fan to see if it runs but it didn't.
I checked the fan socket on the mainboard and 12 Volts appeared on the multi-meter.
Can I be sure that the fan is faulty? Because I don't want waste money on a PSU to find out it was not necessary.
BTW can someone verify that a working TC acts like mine when no fan is connected.
Thank you
Esta é uma boa pergunta?
Pontuação 3
10 comentários
@shoeib hey bro, did you find a solution?
por
@ironjer - I'm sure a new fan fixed the cooling issue
por
@jesus no man. I eventually came to the conclusion that the logic board is fried.
por
@shoeib maybe a bake... mine TC no fan spinning and no front light either but, the hard disk power on. I don't want waste money in new PS. :(
por
@danj I have no front light and no fan spinning, just the HDD works. Maybe the Logic Board is failing...
por
Exibir mais 5 comentários
Adicionar um comentário
2 respostas
Solução escolhida
More likely the fan died here. For about $20 US you should be able to find one.
I don't have a A1470 TC right now but I've had to replace quite a few fan units across the entire line of TC's
Esta resposta foi útil?
Pontuação 1
3 comentários:
Do you by any chance remember how the TC acts with a faulty fan?
Thank you
por
@danj would TG Pro read this?
por
@mayer - TG Pro won't work here. It only works under OS-X or MacOS. The TC's use a custom file system and its own OS. AirPort Utility will report if the unit is overheating.
por
See if any of the following articles can help:
Pontuação 1
Adicionar a sua resposta
shoeib será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 19
Duração total: 2,869
