Ir para o conteúdo principal
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
Replace 1 TB SSD with 2 TB possible?
The new Apple MacBook Pro 13,3" Retina 2016 with Touch bar is sold with a max 1 TB SSD. Is it possible to replace it with a 2 TB SSD?
Esta é uma boa pergunta?
Pontuação 6
1 comentário
For reference: MacBook Pro 13" Touch Bar Teardown. Jump down to Steps 8 & 9 to see the SSD chips.
por
Adicionar um comentário
1 resposta
Solução escolhida
Sorry not possible ;-{
Unlike previous models which had replaceable SSD units, Apple now solders down the discreet flash chips to the logic board. And no, you can't alter them as there is no alternative chip that has larger capacity as Apple is using densest available part now.
Your only option is to use an external USB-C drive.
Esta resposta foi útil?
Pontuação 7
5 comentários:
great answer Dan, thank you very much!!!
(although the result is not what I wanted to hear)
por
Is it possible to upgrade the SDD or RAM by replacing the chips.
por
Chinese: 炫烨 - 不可能
English: Hyun Yeh - Not possible for either
por
Ok what about upgrading 512 to 1TB by replacing the chips?
por
@alsadk - Nope! Apple made it really hard, it's not humanly possible.
por
Adicionar a sua resposta
Agnes será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 17
Ao todo: 5,107
