Ir para o conteúdo principal
Kwickset door handle set with in-knob keyhole.
1 Perguntas Visualizar todos
How do I disassemble the Kwikset Key-In Knob Locket?
I've tried to disassemble it but the cylinder thingy is frozen. It seems to be frozen in the locked position, even though I've used both the key and the thumb lock to try and unlock it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
lauraevalentine , If this lock set is still installed on door, through the key slot, liberally squirt penetrating oil/ WD40 with a small injecting straw/nozzle and insert key in and out/wiggling and repeat several times till lock set works. Below find links for door knob removal and link from kwikset trouble shooting etc. Good luck.
https://www.youtube.com/watch?v=vESDjMTc...
https://www.youtube.com/watch?v=eigYEYR0...
http://www.kwikset.com/customer-support/...
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
lauraevalentine será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 15
Duração total: 1,999
