Ir para o conteúdo principal
The Asus ZenPad S8 is an 8-inch Android tablet by Asus. Released in June of 2015. Model number: Z580CA.
wifi does not work
I need help with my Asus z580c, the wifi is like death, it does not work, you start it but nothing happens, when yo seek into hardware info, it appear wifi undetermined
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
i solved, open the table, disconnect the battery, remove the sd card put it on again, reconnect the battery.
Ah voila there is again the wifi connection.
Esta resposta foi útil?
Pontuação 1
1 comentário:
this helps, thank you. i took it to power off, removed sdcard, restart and its working.
por
I just powered down and removed the SD card and that fixed the problem.
Pontuação 1
Adicionar a sua resposta
Jorge Herran será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 652
