Ir para o conteúdo principal
Repair guides and support for Fujifilm's FinePix line of cameras.
20 Perguntas Visualizar todos
Display warning: Turn off camera and turn on again
I have a Fujifilm FinePix Camera L55 and due to USB broken, I replaced the motherboard, afterward the camera get on normally after charging. with display indicating battery charging, etc. But after trying to setup camera, at a moment the display show this message "! TURN OFF THE CAMERA AND TURN ON AGAIN" After followed up the display instruction for about 3 to 4 times. the problem still there,
Could you indicate if I failed on reassemble or any help please,
Regards and thanks
Louis
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
it is saying turn off and turn on again but nothing is happening
Esta resposta foi útil?
Pontuação 1
1 comentário:
I have turned it off and on again and nothing is happening
por
Hi, thanks for response, Yes, nothing happened, the display stay on this warning: TURN OFF CAMERA AND TURN ON AGAIN...and repeatedly the same warning each time..Regards
Pontuação 0
Adicionar a sua resposta
Louis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 476
