Ir para o conteúdo principal
The dell Vostro is a model in a line of laptops created by dell for business use. The Vostro 1500 was released in 2007.
Keys keep getting stuck
When I press down on my keyboard occasionally the keys will get stuck. Is there any way to fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try blowing under the stuck key or keys with a can of compressed air, this should clean out any dirt or debris that are making the keys stick. If this does not work then the key mechanism may have broken and could need to be replaced. Though it is fairly difficult to break the mechanism in this way so give the can of compressed air a good try.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Timothy Letourneau será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 106
