Ir para o conteúdo principal
The Canon EOS 60D is a 18 MP DSLR (digital single-lens reflex) camera with an articulating LCD screen. The camera was released August 2010 and is identified by the EOS 60D printed on the front of the camera.
Card write protected error
i have canon 60d and it tell me card write protected error when i insert a carrd into it. i have tried 4 cards already and its not the card lock issue. the same card works in other camera. i read in forums its issue with card reader in 60D. would like to if there is any known fixes for this?
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
3 respostas
Pergunta mais útil
I know this reply is too late. But i believe this may help someone in the future.
The same thing happened to me yesterday. I was in the middle of a short film shoot and my camera started giving me "Card write protected" message. I searched in the forums and found that it's the problem with the card reader inside the camera.
I was left out with no other options at that time, so i tried cleaning the camera's memory card compartment by wrapping cloth at the tip of a small knife. And when i turned on the camera, it got worked like magic. :) Give it a try before spending some bucks on servicing it.
Hope this helps.
Esta resposta foi útil?
Pontuação 4
2 comentários:
Thanks u so much, i tried and its really working <3
por
You just saved my life! This was a miracle! Been trying to fix since November 2020.
por
Where can I take it for repair
Pontuação 0
My eos60d protected card erorr
Pontuação 0
Adicionar a sua resposta
Sharon Tom será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 5,479
