Ir para o conteúdo principal
The Toshiba Satellite L305-S5955 is a laptop computer.
Can the cpu be upgrade?
I wonder if i can upgrade from the Celeron 900 to a core 2 duo or a better one? Please email me or answer to this question. Thanks for your help
Update (10/24/2016)
Can the T7250 or the T7300 work with Socket P 478? Or I have to find another model?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
on that list it says partially supported. i wouldn't recommend them unless it is fully compatible. there is a chance that it wont work on your system for those processors.
por
My Toshiba Satellite L-305 has a Pentium(R) Dual-Core CPU T4200 and came with it.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Just to be clear, the GPU is what is integrated. you can see that is evident when looking at the Motherboard that the CPU can be replaced
here is a page that shows you a list of the CPUs that your Laptop will support. Hope this helps :)
http://www.cpu-upgrade.com/mb-Intel_(chi...
Esta resposta foi útil?
Pontuação 2
1 comentário:
So the cpu can be upgrade :) yay
por
Adicionar a sua resposta
quochuyvn1 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 25
Ao todo: 3,098
