Ir para o conteúdo principal
The Toshiba Encore WT8-A is a touchscreen tablet running Windows 8.1.
6 Perguntas Visualizar todos
Why won’t my device turn on?
My device will not turn on even though I hold down the power on button.
Esta é uma boa pergunta?
Pontuação 3
1 comentário:
Student question
por
Adicionar um comentário
6 respostas
Your device’s battery might be dead. You may simply need to charge the device, however if your device has been plugged into a charger and is still not getting a charge, you may need to replace either the charger, or the battery, or both.
Esta resposta foi útil?
Pontuação 0
2 comentários:
I have the same issue. Measured battery voltage and just sits around 3.2v. Ive notice the battery stats show it should be 3.75v. Does this mean the battery wont charge at all? Ive had it plugged in using various chargers and cables to no avail.
At one point toshiba logo appeared on screen before disappearing and then nothing.
Is this potentially a charge port issue? Or flat out battery.
por
@zarmstrong do you guys get credit for answering your own question? just another thing to note is that if a battery wont charge and tablet wont boot you can disconnect the battery for a few minutes and reconnect . This often brings joy
por
This toshiba made tablets are very poorly made product made in a Chinese sweat shop by little 10 year olds trouble do not buy any thing toshiba !!!
Pontuação 0
3 comentários:
My problem is that the power button on my toshiba tablet wt8-b is stuck and won't come back up - have tried to push it down in the hopes that it will come back up but it did not
por
Used a cuticle clipper to push it down but it didn't work - where can i buy a replacement part for the power button on my tablet?
por
Yes yes not buy anything from TOSHIBA because they made the military grade laptops for US Army. Keith Roby how old are you ?
por
If battery life is not the problem, a soft reset may correct the “won’t turn on” issue. Hold the VOL- (volume down) button while pressing the power button. This will put the device into RECOVERY MODE. Sometimes just entering recovery mode and exiting is sufficient to correct your issue.
Pontuação 0
My tablet just flahses and after a bit when I wait it turns on then goes black.
Pontuação 0
1 comentário:
Can anyone help please because I cant afford anything else. Any suggestions please??
por
Hold the power button 45 seconds
Pontuação 0
Why does the Toshiba tablet does not want to onn
Pontuação 0
Adicionar a sua resposta
Zachary Armstrong será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 29
Ao todo: 9,794
