Ir para o conteúdo principal
Fitness and sleep tracking band that also displays caller ID information when paired with a smartphone app. Released in November 2014.
20 Perguntas Visualizar todos
Water damage charge not working?
My husbands fitbit charge got wet and will not work now - where can I get it repaired?
Esta é uma boa pergunta?
Pontuação 5
1 comentário:
I went swimming with my Fitbit watch , didn’t. Go underwater. It no longer works.
por
Adicionar um comentário
1 resposta
Get a quart size ziplock bag , Place your fit bit into ziplock bag cover the fit bit with rice , regular rice that is bought in any grocery store , lock the bag closed for 24 hours . After 24 hours the moisture should be absorbed , see if this helps.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I have met same problem before. Just put it in the the rice. After 24 hours the smartwatch work again
por
Adicionar a sua resposta
Liz Hogan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,688
