Ir para o conteúdo principal
The Game Boy released on April 21, 1989 in Japan, followed by North America on July 31, 1989, and lastly in Europe on September 28, 1990. It is characterized by a large grey casing and model number DMG-01.
Games glitch out after splash screen
My gameboy turns on normaly. The nintendo logo flies down and makes the nostalgic DING sound. Then the splash screen of any game appears but after that the games just crash. With tetris you hear the first note of the title song then it skips back to the splash screen. With super mario land 1 the first screen appears. I press start then the music glitches out and the mario sprite never shows up. I can use the buttons but all the sprites are glitched and messed up. The games work fine in my super gameboy on the SNES so this has to be because of the gameboy not the games. I clead all the contacts in the gameboy and the games.
Here's a video with an example what happens.
https://www.youtube.com/watch?v=pZ2hgeDJ...
Update (09/24/2016)
I tried the alcohol already. I cleaned out the games, I cleaned the gameboy pins multiple times.... Nothing worked. The same problem kept persisting. I'm not really that much of techie so I can't really follow the pcb all that much. I took some photos but I don't know if they are clear enough.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
So you're experiencing this with multiple games? I'm gonna say that one of the IC's has probably gone bad. Do you have any access to another Gameboy? That would be a good way to determine if it's the games or the device. One other thing you could try is cleaning both boards with rubbing alcohol as well to see if there is anything unseen causing a "short" of sorts. Beyond that, something on the board is probably going bad, unfortunately.
por
I tested the games on a SNES with a super gameboy. So the games are deffinetely not the problem. I already tried cleaning the entire board and that didn't help either. I'll try again but other than that I'm stumped. I have a feeling that there is something wrong with the portion of the gameboy that controlls sound. The bug only happens when the music should start. Every splash screen where the gameboy is silent appears normally.
por
Adicionar um comentário
1 resposta
The only easy suggestion I can make is to clean the game pin contacts with some rubbing alcohol. One of the easier ways to do that is to pick a game, clean it with a good amount of alcohol, so it's rather wet and insert it into the game slot, that'll help clean out the contacts a bit. You could also squish the end of a cotton swab a bit to fit it in there and clean the contacts as well.
If that doesn't help, it's time to open up the Gameboy and look over the PCBs. Luckily they aren't hard to follow and you might be able to find some dodgy sections that are damaged in one form or another.
Try out the rubbing alcohol first and see if that helps. It if doesn't, open up the Gameboy and post some pics of the internals if you can't find any spots that appear questionable. You'll probably need a tri-wing driver to open it up as well.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I updated the question to give you more info.
por
Adicionar a sua resposta
vikihochtl será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 737
