No Sound...how to repair?
I have a Nintendo 2ds and the sound doesn't work....is there a way to repair?
Esta é uma boa pergunta?
Tyffani, You are not the only one with the sound on your Nintendo 2ds not working. It may be the ribbon cable connection, internal of the device or if your volume control feels very free, the switch may not be connected to the internal mechanism. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button.
http://en-americas-support.nintendo.com/...
Esta resposta foi útil?
@lucsen, Lucsen, check out the advice and links above to trouble shoot your issue.
Related Parts and Tools
Shop allÚltimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 7,001
1 comentário
Me too some times there's loads high pitched noises
por Lucsen
