Ir para o conteúdo principal
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
How to replace trigger spring?
Hi, I've got a controller that was dropped and the trigger is now loose. When I opened it up I see that the small spring that pushes the trigger back up is broken. I have a replacement spring and bar, however I can't seem to remove the old one. Anyone smarter than me out there got any tips?
Thanks.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
doubtful there is anyone here smarter than you, google is your friend.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
There should be a bolt through the middle, holding it in place. You can stick a needle or something small and thin in the end of it and it will come out.
Esta resposta foi útil?
Pontuação 2
bend a paperclip to push it through
Pontuação 0
Adicionar a sua resposta
barrypearson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Ao todo: 7,777
