Ir para o conteúdo principal
I can hear just on one ear
i tried it with some headphones all working but i can hear just on the right ear the other side just dont work=how can i fix it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Solução escolhida
replace headphone jack
Esta resposta foi útil?
Pontuação 0
on Bose QC25 The right side isn’t working, i did replace the wire, any tip?
Thank you
Pontuação 0
EASY !!!!
In most cases, it is the speaker that is the problem !!!
Easy to change:
1. 2 screws inside the earcups and the cloth piece (The earcups are "clips" on plce...use your finger all the way around until you hear click....every 2 cm.....)
2. Use a scalpel to open the cover of the speaker (NB!! warm up a bit first...hair dryer works fine!)
3.Unsolder the speaker and solder a new one !!
EVERYTHING OK !!!
Pontuação 0
Go to Settings - Accessibility - Audio/Visual and check if Balance is right in the middle - I remember once it got messed up by itself for absolutely no reason, but I fixed it this way in seconds
Pontuação 0
2 comentários:
Why should yoy do this....? when it is no sound in one of the speakers...?
whats the Point...?
por
Try it - you’ll see ;)
por
Adicionar a sua resposta
yuval será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 855
