Ir para o conteúdo principal
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
screen presses buttons by itself
what is causing this? its phantom touches?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
my rca viking pro will not work if i drtatch the keyboard so therefor i am unable to use touch screen it completly stopped
por
Adicionar um comentário
2 respostas
Solução escolhida
Has this tablet been dropped or repaired? It's definitely a touch issue with the digitizer itself. These issues can be software related, but they rarely are. Is there a warranty left on it by chance? I know a lot of repair shops that dont touch tablets like this because they are either not worth fixing since the repair may cost the same or more than a replacement or the parts are hard to find. If you have your data backed up, Id wipe the device and restore it to factory just as a last ditch effort.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I did reset it to factory condition and it did stop, but there is still a dead zone on the side that fits into keyboard. I don't use the keyboard except for a stand, so if I remove it I can flip it around and get around the dead zone. It's somewhat annoying but I can live with it.
por
Unfortunately, it does sound like a hardware failure. The good thing is you can work around it. I hope it doesnt get worse.
por
Go into your control panel , click hardware and sound, then click device manager under and find a option to delete touch device under human interface devices , or something that says that, i deleted it so I forgot what it’s called. So now my screen doesn’t touch by itself .
Pontuação 0
Adicionar a sua resposta
Susan Thomas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 2,613
