Ir para o conteúdo principal
Replace A1150 display with A1226 display?
I have a 1.8GHz A1150 that has a dead display. I have a 2.2GHz A1226 with everything dead except for the display. Can I put the A1226 display onto the A1150? It looks like the isight and inverter connectors are different, but the display data cable looks the same. I guess it wouldn't be a straight swap, but maybe I'd have to open the display itself?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Unfortunately, you cannot swap these LCDs. On the LCD the data cable ports are in different locations, the A1151 has it at the top, while the A1226 has it at the bottom. There are probably additional reasons, but that one is the most obvious.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Kerry Lambert será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 2,333
