Ir para o conteúdo principal
Repair information and support for walk-behind lawn mowers made by the Toro Company.
How to replace cord
What size of wrench/socket is needed to remove cover?
Esta é uma boa pergunta?
Pontuação 2
3 comentários:
Would you mind giving us the model number?
por
ph-xt675-2011 pull cord wont rewind
por
need 10mm socket to take top off
por
Adicionar um comentário
2 respostas
Well that depends on the size of engine u have . (I'm sorry if my answer sounds rude kk) Now, hopefully u have ur Sockets still in their boxes that they came in. If u do just use ur common sense and take one socket that u might think will fit. If it doesn't then try another one. And eventually u will find the right one that fits.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Would that be metric or standard sockets? Would a cresent wrench work? Why does the cover need to be removed? What are they trying to fix? Do they need a guide? Shouldn't you find out what model it is first as Toro has been making engines for over 100 years? Is this a gas or electric engine? Is she looking for a replacement electric cord or a replacement engine start cord for a gasoline operated machine? Should she go here and enter her model number to find the replacement part? https://www.torodealer.com/en-US/Pages/p...
" 'Course that's just my opinion, I could be wrong."
por
No your not wrong. All your questions are Valid ones
por
the cord you pull to start the engine is locked . What do I need to do to free the cord?
Pontuação 0
Adicionar a sua resposta
mojokatt57 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 670
