Ir para o conteúdo principal
Repair information for the Sony Bravia 4K 55" Ultra High Definition Smart LED TV. Released in 2019. Model number: XBR-55X950G.
YouTube giving an error 'please check your network connection'
Hi I just connected my Sony TV to the Internet three days ago. YouTube was working fine the first day. And now it is not working. It keeps giving me the error message 'please check your network connection' everytime I try to get on that app. I checked my Internet connection, I am able to get on Netflix without any problems. I also switched off everything unplugged and replugged the wires, and still unable to get in YouTube app on TV.
By the way, YouTube works fine on the other laptops and phones.
I did do photo plus sharing from my phone to TV end of the first day. Could that have to do with any of this error?
I'm posting for the first time, don't know how this site works, I hope I get notified.
Esta é uma boa pergunta?
Pontuação 15
11 comentários
je ne comprends pas pourquoi ? je ne peux connecté avec le logiciel tango pour partager avec mes amis dans le monde à cause network qui est toujours un message de check network connexion encore une fois.
por
I have the same problem with my YouTube it’s always saying connect to the internet on my phone I deleted the app and downloaded it again but is not working it’s always saying that u are not connected to the internet error what should I do please help
por
Hi, I have the same problem un-installed the app and deleted the app cache and still the error message keep appearing.
por
I foresee this as a major problem that will damage these tvs I think that the software should be updated to automatically clear the cache upon turning off the set so that you start in default mode when you want to watch TV again and not be in a network loop this will perhaps break your tv set it is the same principle of computing the longer one ignores problems upon startups the likely hood of a total system error crash is to occur
por
hai i connect it to internet it succeed .but it show " service cannot access at this time" can you please give your solution or please contact me pradsanth@gmail.com
por
Exibir mais 6 comentários
Adicionar um comentário
7 respostas
Pergunta mais útil
Hi,
Try clearing the cache for the You Tube app in the TV. Not sure how it appears but if it is based on Android, go to apps main menu > settings > applications > select either downloaded or all, scroll down to You Tube, click to enter. Select Clear Cache and then try it. If it doesn't work try Clear Data, which should be located there as well.
Esta resposta foi útil?
Pontuação 2
3 comentários:
but the data said All of this application data will be deleted permanently. this includes all files, settings, account, databases etc. What should i do? Should i click yes?
por
Hi,
If you are not having any other problems with your internet connection other than when you use your You Tube app then unfortunately, the only way to resolve it is to either uninstall/reinstall the app or try clearing the app's cache. Either way it will result in all the settings and info for that app being deleted. If the cache is corrupted it has to be deleted so that fresh information can be stored there. Again it is only information pertaining to that app that will be deleted, so verify that you know all the relevant personalized You Tube settings info etc before you clear the cache and delete them so it is easier to re-enter them afterwards
por
Oh! Thanks God the problem solved. Thanks for help!!!
por
Gear Up For Future Repairs
I cleared cache and data AND went to change the date and time of the TV. Oddly it was set at network time which was in 2016. Changed to current date and it worked!
Pontuação 2
6 comentários:
This worked for me too! Glad I found this site -thanks Ellen!
por
Its worked for me too!!! Thx for the sharing..
por
how to clear cache plz?
por
Yes it works!clearing youtube app and changing the date to current.thanks for the info.
por
Change the date and time to Network Time it worked!! Thanks
por
Exibir mais 1 comentário
Another tip. Hold down the POWER button on the remote and the TV will do a hard reboot (not to be confused with reset).
Pontuação 1
1 comentário:
It works! Thanks a lot!
por
hi. idk but this happen to me this is what i do and it works just change the right time or date im not an expert but this work to mine
Pontuação 1
I am on my iPad iOS and i can not access my 'applications' so I can fix this YouTube error ,can someone explain step by step if you can?
Pontuação 0
1 comentário:
This is completely different than a Sony TV.
for iOS Tap and hold the Yahoo icon until all the apps start shaking with an "x" in the corner. Tap the "x" to uninstall the youtube app. Now redownload it from the app store.
por
I just change the correct date and time from the settings and youtube is working again.
Pontuação 0
1 comentário:
An encrypted I would like my dear back 🔙 Wi-Fi network some unlock all countries please that your've got on me you have got hold of my dear please let it go like a bit back private just to me please and I'm sorry
por
I have a question not working for me vevo network doesn't need to be VPN connection I don't know cloudflare anymore
Pontuação 0
2 comentários:
I do not know him please ray I'd I would like to have access full-time
por
Cloudflare I I would like not encrypted keys exist to me like you to unlock me from your guys I would like connection it's secure that's what I would like
por
Adicionar a sua resposta
Krina Patel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 40
Ao todo: 102,197
