Ir para o conteúdo principal
A business-class notebook with a 13.3" touchscreen display.
How can I replace my LCD Screen?
My screen recently broke, it refuses to turn on. I read through the tear down and was unable to determine what I should do in order to replace the screen.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi Mitch,
Try taking a look at the LCD replacement guides for similar models. The HP EliteBook 8440p has a LCD replacement guide and so does the HP EliteBook 6030p. You can also find a replacement part on Amazon. The replacement LCD for your laptop can be found here. Be sure to double check your model numbers to be sure you've ordered the correct part. Good luck!
Imagem de HP Elitebook 6930p Display Assembly
Guia
Removing the HP Elitebook 6930p Display Assembly
Nível de dificuldade:
Moderado
45 minutes
Imagem de HP EliteBook 8440p LCD
Guia
HP EliteBook 8440p LCD Replacement
Fácil
20 - 30 minutes
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Mitch Kev será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 2,833
