will not boot up
After pushing the power button, it shuts itself off 3 to 5 second after pushing the power button
Esta é uma boa pergunta?
It could be a problem with static discharge , if so do the following.
1. Disconect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds , then release for 30 sec and then hold down for another 30sec
4. Plug in power ,replace battery and power on laptop.
If this causes no Joy try this.
Remove memory and reinstall one stick at a time, if there are more than 1 dimm of ram, try each stick in each slot one at a time to see if the memory is ok and to determine if one of the memory slots is bad.
Hope this helps
Esta resposta foi útil?
I haven't ever opened up a laptop, isn't it risky?
Fantastic, who's a clever boy then? Problem solved on only the second page. Laptop going off after 10 seconds. Thank you so much.
I wonder if you could help me further please. I have been given an Eee small lap top. Unfortunately the owner didn't tell her husband the password before he died so I can't get into it. It turns on OK and then stops. I have all the cables and books etc.
Regards and thanks again. Alan.
Alanbeasley@virginmedia.com
get error code 00000000.0E will not reboot to factory mode i dont have cd to reboot
I have not opened my computer for almost 1 year and it is not strating and the charger light is not lighting too
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 26
Ao todo: 5,117
3 comentários
do you get any error screens? does it get to the boot screen ? how far into the boot do you get
por Jimfixer Compartilhar
I can get to the boot screen sometimes and it still just shuts off with a little popping sound
por raishard Compartilhar
I will try that thanks
