Ir para o conteúdo principal
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Pergunta encerrada
How to determine if the LCD is bad after drop
Hi,
I have an iPad air that was dropped about 4' onto a ceramic tiled floor. The iPad landed on the left edge (opposite of volume control edge). After the fall, the screen is white/grey with horizontal lines. The lines are not consistent and seem to change from just a few to sometimes filling the whole screen.
I successfully removed the front glass and LCD and unplugged and replugged the associated connectors and reassembled. I did this in an attempt to correct any possible connection problems. Alas, this did not correct the problem.
I was wondering if my problem is most likely a damaged LCD and replacing the LCD would correct the problem. Is there a way I can determine that the problem is a damaged LCD?
I'm willing to purchase an LCD if I can get some sort of confirmation that this would resolve the issue.
If I purchase an LCD and install, but it does not resolve the issue, may I return the LCD for a refund?
Thanks,
Kevin
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Yes, this is likely a broken/damaged LCD. Go ahead and replace it.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you, Jim.
I'll give it a go.
por
Hi Jim,
I'm hoping you can help me once again. I successfully installed the new LCD and it did correct the visual issue. However, I now seem to have a touch problem where the touch signal is is located in a different position than where I actually touch the screen. For example, if I touch 5 on the passcode entry screen, the 1 is selected. Also, the touch reception seems to be intermittent.
I'm now thinking that the screen/digitizer may also be damaged and need replacing. What are your thoughts?
Thanks again for any help.
Kevin
por
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,154
