Ir para o conteúdo principal
No sound! Do I need to replace my Left I/O board?
About a year or so ago I dropped my MacbookPro2,2. There is a huge dent in the bottom of the case, as if it fell on a rock or sharp point, which caused the LCD panel to be severely shattered, and my sound to die. I've been using it as a desktop with external LCD & USB sound card, but am thinking of giving it a bit of a repair so I can use it as a media center, so sound is very important.
The sound doesn't work at all; no speakers, no headphone, no digital-out optical, etc. The dent is close to the left hand side of the machine, so I'm hoping only the Left I/O board was damaged in the process. Two questions:
1. Are these symptoms common to Left I/O board failure?
2. And are all audio related circuits on the Left I/O board alone and not on the logic board?
Thanks guys
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Replacing the left I/O Board should resolve your problems.
Esta resposta foi útil?
Pontuação 1
1 comentário:
+ agreed
por
Adicionar a sua resposta
Adrian será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,600
