What is causing my wheels to get stuck?
The back right wheel on my stroller keeps getting stuck and the wheel wont turn.
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
If your wheels are getting stuck, you should check to see if any debris is caught in them. If all the wheels seem clear, it may be that one or more wheels are damaged. If this is the case, try and identify which wheel or wheels are giving you trouble. You can then replace the damaged wheels using the Wheel Replacement Guide for specific instruction.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 5,370
