Ir para o conteúdo principal
HP Envy TouchSmart 15, model 15t - j000. Release year 2013.
20 Perguntas Visualizar todos
My battery life has reduced significantly.
My battery life percentage runs out more quickly than it used to. Why is that?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Solução escolhida
The battery after many charge and discharge cycles will lose it's ability to hold a charge. Extreme changes in temperature can also reduce battery life, as well as keeping it plugged in all the time. You should let the battery completely discharge once and a while to help it have a longer life. If the battery is unusable for your needs, you should replace it.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Giovanni Morales será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 380
