Ir para o conteúdo principal
What to do if the screen is white?
the ipod is dead and the screen is white what do i do to fix it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
hmm - that makes no sense ;-)
is the ipod dead or does it show a white screen??
dead would mean: screen is black and doesn't show anything, doesn't react when you connect it to the computer - it would simply be dead
white screen would mean: the WSOD (white screen of death), the ipod can be switched on but does only show a white screen!
there are a few things you could try
  1. make a hard reset: press and hold the home and the sleep button at the same time until the ipod restarts (should take 10 seconds) - if your lucky - the ipod will work again after the boot process
  2. if the ipod was dropped - it could also be a connection problem - you should need to reseat the lcd connector (if it was dropped and reseating didn#t help, the lcd could also be broken in the upper area - in that case the lcd needs to be replaced)
  3. if the ipod had a fluid damage and shows the white screen, it could be a shorted connection or a toasted lcd controller (that would be the worst thing)
i'm sure that there are other things too that could led to the white screen - but those are the most common issues
Esta resposta foi útil?
Pontuação 4
1 comentário:
Related Parts and Tools
Shop all
you need to tear apart your itouch and get to the lcd screen. with a multimeter check to see if the fuse on the lcd screen is open.
Pontuação 1
1 comentário:
lol - you should tell people where the fuse is when you give them the advise to check it ;-)
por
Adicionar a sua resposta
amanda será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 1,441
