Ir para o conteúdo principal
The HTC Evo 4G LTE is an Android smartphone developed by HTC Corporation to be released exclusively by Sprint.
Pergunta encerrada
What makes it shut off and on?
can deleting apps make it malfuction
Esta é uma boa pergunta?
Pontuação 0
1 comentário
thanks mr. black BUT CAN IT BE REVERSED?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Yes it can. Also rooting your device and messing around with stuff can do that too. Changing it's resolution, etc. Lots can go wrong when you play with things. If you don't know what your deleting .... usually best to leave it alone.
Esta resposta foi útil?
Pontuação 1
2 comentários:
thanks mr. black, but can it be reversed
por
Yes you have to re-flash your rom and reinstall your Gapps (google apps). Watch a tutorial on YouTube. It's easy enough and after a couple times. You can unroot your phone too but doing a factory reset should fix everything. Just hard reset your phone first before playing with custom roms etc. Most phones by default are volume down and power button at the same time when starting to go to recovery. Might be different for your phone. Just take a look on google if that doesn't work.
por
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 116
