How do I get roof off to fix
It seems like the top is a nut, but cant turn it.. I read other answers .. does this model have four snap-ins or what
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
You have to work the plastic piece from the top of the carousel. Under it you will find a screw. Remove the screw. Then turn the carousel on its top. You will see places around the edge that you need to use a flat screwdriver to pry the locks loose. Hope this helps.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 345
