Ir para o conteúdo principal
2.3L 4cyl or 3.0L V6, 6th Generation
Replace fuel line that goes to fuel rail
2002 Honda Accord, how to replace fuel line
Esta é uma boa pergunta?
Pontuação 1
2 comentários
What engine size? why do you need to replace it?
por
A pack rat has chewed a hole in it.
por
Adicionar um comentário
2 respostas
Solução escolhida
It depends on if the line is the high pressure side of the return line. If it's the return side cut the line clean and splice in a piece of high pressure fuel line that fits as snug as possible and double clamp it with hose clamps at each end. If its on the high pressure side you can get compression fittings at your local auto parts store and splice in a piece of plastic fuel line.
Esta resposta foi útil?
Pontuação 2
what size are the lines : feed, return, vapor . I found a kit that has all 5/16 size - not sure. And what about quick connects and flares . Brake lines were pretty straight forward , not sure with these .
Pontuação 0
Adicionar a sua resposta
Robert OFerrall será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 5,319
