Ir para o conteúdo principal
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
Crashed and threw Error code -22
My friend gave me his Ipad 3 after he said it crashed and then while he was trying to restore the ipad it threw the error code -22.
I took the ipad home and was able to connect it to itunes and try a restore, it said unable to restore and it gave me the option to restore again, which I did. Now the ipad is not holding a charge and can't charge or even be "seen" by my cpu.
What does error -22 mean, and how can I fix it?
I know how to tear apart an Ipad and put back together correctly.
Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Follow this link for information and way to restore the issue:
https://discussions.apple.com/thread/481...
Esta resposta foi útil?
Pontuação 0
1 comentário:
I don't know anything about software, and also the iPad can no longer be "seen" by my cpu.
por
Gear Up For Future Repairs
Shop all
Hey there,
Error code 22 is a Device Manager error that occurs when a device is causing a problem. This error code indicates that the device is disabled in Device Manager. Error code 22 can be fixed by enabling the device in decvice manager.
Pontuação 0
1 comentário:
How do I go to device manager if my device will no longer power on?
I don't understand how error 22 makes my device lose the ability to hold a charge and power up.
por
Adicionar a sua resposta
Andrew será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 3,036
