Ir para o conteúdo principal
Compact video camera recorder/tape recorder Released 1989, Model No. CCD-TR5 Serial No. 257152
Why is the viewfinder show blank white
I can not see through it
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
Try to put in to camera mode, on the top there is a black with green switch turn or swap it to the left. (Sorry for My bad English I'M From holland)
Esta resposta foi útil?
Pontuação 2
This didnt help for me, its still white. In play aswell as camera mode. Its flickering and when FF or RW is pressed it also flickers how i would expect it to but still only white. When i first powered it up i saw like 1sec Snippets of image then white again, now only white and Flickering
Pontuação 1
I have the same.. Any answers?
Pontuação 0
I have the same issue. I suspect it’s a power/regulation issue or a video board issue with the Surface mount electrolitic capacitors that dry out or leak over time. I ordered some of these capacitors and I’m going to replace some of them and see if it helps to restore the picture.
Pontuação 0
2 comentários:
Did it work?
por
It revived the viewfinder but I still had a garbled picture. There still is something wrong on the video board in the camera.
por
Adicionar a sua resposta
paxton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 33
Ao todo: 3,447
