Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
Some problems after Battery replace
Hi,
I have changed my battery and i have a lot of problem...
First i have change the battery and i have a problem, the Touch Id doesn't work.
In Settings when i want to activate it, it's written "Fail".
I don't know why, because i have desassembly the phone without problem..
Few days later, i need to charged 3/4 times my iPhone per day and it's a new Battery ( very good quality buy here) and my External Speaker Doesn't Work...
What can i do ?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
Have you tried to restore from itunes?
por
Adicionar um comentário
3 respostas
Solução escolhida
You may have accidentally damaged some components during installation. Have you inspected the ribbon cables to see if there is any damage? It's always a good idea to go back through and make sure all the connections are clean and fully seated. You can clean them with isopropyl alcohol on a cotton swab, and make sure they're completely dry before you close up the phone again.
Does the home button click function still work?
Esta resposta foi útil?
Pontuação 1
1 comentário:
Yes the home button Work, just the Touch ID and the external speaker doesn't work..
por
Related Parts and Tools
Shop all
Download a programme on laptop called ibackup bot it will actually tell you how many times the battery has been charged..
Most new batterys you get are never original and have been charged I've 100 times unless you have a good supplier
Pontuação 1
I had the same problem, found sensor cable was not seated fully. Took quiet a few goes to get it right.
Pontuação 0
Adicionar a sua resposta
robinphi58 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 213
