Ir para o conteúdo principal
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
battery A1416 IPAD WI-FI THIRD GENERATION
HI,
WHEN I CLICK THE LINK FOR BATTERY A1416 TO ORDER IT, ITS SHOWS ME THE BATTERY A1389. IT IS NORMAL ? I DONT WANT TO BUY THE WRONG BATTERY AGAIN. THANKS FOR YOU HELP!
JENNIFER
MONTREAL, CANADA
iPad 3 Wi-Fi Battery Replacement,
Esta é uma boa pergunta?
Pontuação 1
1 comentário
A1459 Does not show that it is charging at all. Connections seem tight and clean. Tested with various cables and chargers. Would this likely be just the battery itself, or any other possibilities?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
I do not care for the way Apple numbers its batteries as it makes them look like model numbers instead of part numbers. Here’s your correct battery:
COMPATIBILITY
  • iPad 3rd Gen A1416, A1430, and A1403
  • iPad 4th Gen A1458, A1459, and A1460
SPECIFICATIONS
Part #:
616-0593, 616-0592
Model #:
A1389
Watt Hours (Wh):
42.5 Wh
Voltage:
3.7 V
iPad 3/4 Battery
Imagem de Replace a battery compatible with 3rd and 4th Gen iPad models A1416, A1430, A1403, A1458, A1459, A1460. Part #616-0593, 616-0592. Battery model A1389. 42.5 Watt Hours (Wh). 3.7 Volts (V).
Produto
iPad 3/4 Battery
$39.99
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
jenelly51 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 410
