The trigger doesn't do anything.
Whenever I pull the main trigger on this gun, nothing happens, even when I have primed the gun.
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
There is most likely a broken piece of plastic in the trigger assembly. I would just buy another one if I were you.
Esta resposta foi útil?
The issue might be that the trigger is stuck due to some residue or dirt getting lodged in the trigger slot. You can solve this problem by removing the trigger and cleaning it with soap and water. If it turns out the trigger is actually broken, you will have to get a replacement trigger. Refer to the troubleshooting page.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 321
