Ir para o conteúdo principal
Sony’s 18.2 megapixel camera meant for general photo taking, 3D images, and filming. Model number: DSC-WX100.
Pergunta encerrada
How to repair an offset frame?
After I made a component replacement in my camera, and upon trying to reassemble the camera, the frame of the camera is not fitting correctly. When trying to insert a screw inside of the HDMI port, the frame was offset enough to the point where a stress fracture was visible on the frame.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Putting the frame back for the camera is tricky since there are multiple connections, so you have to take careful note when disassembling the camera. Our disassemble guide can offer assistance for you in this task. Another thing is that the parts have become worn or broken, in this case you will have to replace the casing.
Esta resposta foi útil?
Pontuação 0
Related Parts and Tools
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 183
