Ir para o conteúdo principal
Repair and disassembly guides for garage door openers.
18 Perguntas Visualizar todos
remote opener works close up - but no range
T/S progress so far:
New battery and several different remote control - same result
- can control with wall switch but remote more than two feet away does not work - works within one to two feet.
- suspect receiver circuit in opener - maybe front end not working.
can't find schematics to get in deeper and replace failed component. Any help appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Check your drive unit (on the ceiling). See if there is a small wire hanging down from it. That is the receiver's antenna. If the wire is there, be sure it is attached. Some models don't have an exposed antenna. http://ep.yimg.com/ty/cdn/linear-access-...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
patrickmoretti será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 245
