My laptop not showing anything on display.
My laptop cannot show anything on the screen and the fan is not spinning but the power-led is on. What is the possible problem of this.
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
My screen is black and I do not have a fan sound
Esta resposta foi útil?
Ditto! I have pulled out the memory, HDD, keyboard, hooked up to external monitor and nothing. When I power on, I get two LEDs on in the front, but I can see the fan doesn't move (because keyboard is removed). I am going to replace CMOS batt... maybe that is the problem?
toshiba motherbore c660 gone what can i do to reply it
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 2,833
try an external monitor first and see if it shows anything.
por oldturkey03
Same problem. Black screen, no sound but fan noise. Both leds green.
I hope mobo is still alive. I'll try to reset BIOS removing little battery.
por lillofiretto
Try re-seating the Memory. If the fan is spinning up abnormal loud try to re-seat the Cpu.
por Goulithum
I have the same problem. It powers up with a blank screen, fan goes on, then suddenly it powers out.
por Carlos Gardea
Ditto here. I see the fan is not spinning because I took the keyboard out. I have removed memory, HDD, plugged into external monitor... nothing.
por Mike Caron
