Ir para o conteúdo principal
Two-wheeled, human-powered transportation. Decide if you want to search for your bike, the specific component or browse the troubleshooting wiki in the related pages section.
20 Perguntas Visualizar todos
Why does my rear suspension make noise?
i am from India.. &i have hero next bicycle.
whenever i drive it or when the rear suspension is used.. th e cycle makes noise like .. chooo///socho.... please help me ..
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
It could be that the Spring ist not tightened enough, so it could move between the damper and the big Nut. If the Damper comes out by using the Negative damping and the Spring can move, it could be that the Spring you are using is for a bigger Loading (It means that you are too light for this Spring)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Digvijay Singh Bhati será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,049
