Ir para o conteúdo principal
Schwinn Mens Tourist 28"/700c Road Bike
8 Perguntas Visualizar todos
When does my bike chain pop off randomly?
The chain on the bicycle continues to get stuck and come off randomly when riding.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Pergunta mais útil
If you brought this bike to me I would first check to see if there were any stiff links. To do this I would put the bike in my work stand, and rotate the crank backwards, looking closely at where the chain runs through the rear derailleur.
I would also ask you about where it comes off the system. Does it pop of the front chainwheel or at the rear wheel. Does it come off on the outside or the inside of the front chainwheel?
The answer to these questions will help to pin-point the cause.
If the chain comes off at the front chain wheel on the inside, then the derailleur "low" limit screw is not in enough. If the chain comes of on the outside, then the "high" limit screw is not in enough.
If while spinning the crank I notice that the chainwheel/chainring is not straight, then THAT could be the cause.
Does the chain come off while pedalling under load? For example when you are standing on the pedals and pushing hard? When cycling up a hill, or when you are changing gears on the front, or on the rear?
Many questions, but all help to troubleshoot the cause.
Also, have you ever crashed the bike, especially on to the right side? This could cause a bent rear derailleur hangar. Which would need to be replaced.
Take a look at ALL of these situations to try to pin-point the cause. If you are troubled, take it to the local bike shop with the best mechanic reputation.
Esta resposta foi útil?
Pontuação 1
There are many causes to a bike chain coming off. First, check to see if anything is in the track of the chain. Secondly, check to see if the chain is rusted or needs to be lubricated. Lastly, the length of the chain can cause the chain to pop off if it is too long or short.
Pontuação 0
#1.your teeth on your sprockets might be worn.
#2.your chain might be too loose.
#3.your chain might be rusty, depending on how rusty and if the links don't move freely you probably need a new chain..
Good luck
Pontuação 0
My wife's chain keeps poping off.
Pontuação 0
Adicionar a sua resposta
Quandre Mebane será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 3,332
