Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Buy internal SSD?
Where can I buy an SSD for my iMac Retina 5K ?
I would like to replace the one on the motherboard and not the SATA 3TB.
I have a Fusion Drive 3To, I would separate them and I would like a SSD 512 GB only for OSX (because 128 GB is too small) and my 3 TB for storage.
This SSD on Crucial Store look be not compatible : http://www.crucial.com/usa/en/ssd/ct512m...
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Sorry this is not a compatible unit
por
Adicionar um comentário
2 respostas
Solução escolhida
Not yet. It's proprietary that means there are no 3rd party sources.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Presently Apple is the only source for the custom SSD units they use in the iMacs.
To add to the confusion the specs for the SSD's have changed a few times between the different series so you can't use the older SSD units in your new 5K iMac. For now you'll need to wait.
Here's some better sources to watch:
Pontuação 1
Adicionar a sua resposta
Cyril será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 268
