Fusion & Flash Storage
I am not asking about performance. I'm not asking about how any software works. I am asking about the physical components installed in the iMac 27" w/5K Retina display.
Some say Apple's machines are not designed to be opened. They are not designed to be upgraded. That is not the topic. If something is cost effective is not the topic. If something is time consuming or hard is not the topic.
This is a hardware site, other sites do reviews and software Q&A.
If I order a Fusion Drive for a iMac 27" with 5K display, I can get a 1TB HDD and 128GB of solid state flash storage. AKA the meaning of Fusion via it's marketing words.
If I order the non-Fusion Drive, I can pick the storage capacity I want, but for this case, I pick 256GB of solid state flash storage.
So now there are 2 storage options (fusion or flash) to compare which comprise 3 different physical pieces; 1TB, 128GB, and 256GB.
I'm not asking about speed, performance or capacity, or which is better or worse. I am not asking about the spinning hard disk.
The 128GB of solid state flash storage connects to the logic board (obviously), so does the 256GB.
Question #1:
is the only difference between the 128GB of flash storage (available via "Fusion" configuration from Apple)
and the
256GB Flash Storage, the fact that the capacity of 256 is twice 128?
I am asking about how the flash storage connects to the logic board. I am asking about what chip sets are used to make up the final capacity (128 or 256).
As seen here:
'''http://ifixit.org/blog/6766/imac-27/'''
For above, in Fusion configuration, the memory chip is SanDisk 05131 016G 16 GB NAND Flash (8 x 16 GB = 128 GB total)
Question 2:
Maybe not a SanDisk chip, but the specs, connection, etc. are they the same between fusion solid flash storage and non-fusion solid flash storage, both PCIe blade?
True or False (question 3)
Situation 1:
A - Order Fusion Drive iMac 27" with 5K display
B - Remove spinning hard disk drive
Situation 2:
Order 27" w/5K with 256GB Flash storage option
does above situation 1 minus 128GB = situation 2? Am I missing something with this?
True or False (question 4)
If I order 27" iMac w/5K and get the 256GB Flash Storage option, there is no physical mount or retention device included in the machine to allow for a standard hard disk to be installed?
True or False (question 5)
If I order 27" iMac w/5K and get the 256GB Flash Storage option, there is no SATA connector available on the logic board to connect a SATA storage device later?
True or False (question 6)
The logic board is unique based on the the flash storage option? (I don't think this is true, but some have said the flash storage is soldered). So this is really 2 questions...
True or False (question 7)
For either Fusion or non-Fusion the solid state flash storage connects to the logic board using an Apple proprietary connection and not a mSATA?
True or False (question 8)
Order a 5K iMac with Fusion option.
(assuming removable)
Remove internal rotational HDD.
Remove internal 128GB solid storage.
Install of 3rd party SSD not possible without some retention device?
True or False (question 9)
Order a 5K iMac with 256 flash storage
Flash storage fails within warranty
Return for repair
Repair =
unplug broken 256GB apple proprietary PCIe blade
then plug-in new 256GB blade
Could a 512GB/1TB blade be installed rather than the original 256GB? (of course apple does what they do, but what would make sense based on the machine's internals)
I know many people are talking about the design and the 5K. I know people are not talking about RAM because it can be upgraded at will. Because the processor isn't fixed to the logic board, there's not much conversation there.
No one is really talking about storage. Why? Is Cloud storage what's needed? Is thunderbolt so fast that nobody cares how much internal space in within the machine?
Esta é uma boa pergunta?
6 comentários
Greg, Boy what a list of Q's! How about cutting it down a bit here (how about 5 q's). Focus on the main points simple and straight on what you're objective is.
por Dan
Also did you review the iMac teardown? Review this: iMac Intel 27" Retina 5K Display Teardown I think some of your questions can be answered there.
por Dan
Dan - yup a crazy list of questions.
The main point I want to understand is if the solid storage (non-fusion) is the apple proprietary connector and what the difference is between model configs for the solid storage. If I buy a 256 non-fusion config and a 1TB non-fusion "flash storage" stick is in my possession, can the 256 be replaced with the 1TB?
If there is no real different between the solid storage of the fusion and non-fusion options, the fusion could be "broken" having 2 independent disks. And later when larger "blade/sticks" are available 128 could be changed. The only reason to order a non-fusion option is because a capacity larger than 128GB is wanted.
It seems to me the original iFix tear down doesn't investigate the difference between fusion & non-fusion machines. But that's not a criticism, I understand that nobody has seen the insides of these machines.
The 404 broken link had quotes sorry. Blog tear down - linked here:
por Greg
The teardown is just that a breakdown of the unit. It does not get into the details of how the systems storage can be configured.
por Dan
Sounds to me like you expect to customize the family car (iMac) attempting to turn it into a pickup or dump truck with after market beds. . . not feasible. There are three on-board storage connectors, two are SATA one is proprietary. As Dan explains below (at this time) only Proprietary Blade drives fit this connector. Its possible that in the future someone may make an adapter or find a source for larger blade drives Are there larger blade drives, and where and when will these drives become available are imponderable questions. Looking to the future with more and more storage desirable on an iMac, and even the MacPro external drives are the soluiton... which may also be "fusion" drives.
por originalmachead
Exibir mais 1 comentário
