Ferramentas utilizadas neste teardown
Vídeo de Apresentação
Introdução
Think of the most colorful and radiant display you’ve ever seen. Now, discard that memory and stare at Apple’s newest iMac Intel 27” with Retina 5K Display. We're not talking 1080p or 4K, we're talking about 5K—millions and millions of pixels on a 27-inch display. Will the addition of a high-resolution display affect the repairability of the newest iMac Intel 27”? Let’s find out!
Follow us on Facebook, Instagram, or Twitter for the latest teardown news.
How do you herd together 14.7 million pixels? You can ask nicely, or you can brandish some heavy-duty hardware. Inside the Retina 5K iMac:
3.5 GHz quad-core Intel Core i5 processor, with Turbo Boost up to 3.9 GHz
8 GB (2x4 GB) of 1600 MHz DDR3 RAM
AMD Radeon R9 M290X graphics processor with 2 GB of GDDR5 video memory
802.11ac Wi-Fi + Bluetooth 4.0
PCIe-based SSD storage and SATA hard drive
Not one to waste a good model number on just a single device, Apple again recycles A1419.
At the rear of the iMac, we find a plethora of I/O ports and a lone SDXC card slot:
Headphone jack / Optical digital audio output
SDXC card slot
Four USB 3.0 ports
Two Thunderbolt 2.0 ports
Gigabit ethernet port
Fixers rejoice! The iMac Intel 27" Retina 5K Display retains the familiar, easily accessible RAM upgrade slot from iMacs of yore.
For those who require assistance replacing their RAM modules, Apple has attempted to provide some direction—that you get to see after you're halfway through the process.
We're pretty adept at slicing open iMacs with our ever-so-fancy
pizza cutteriMac Opening Tool and our noble Plastic Card. -
While the procedure still requires a steady hand and a willingness to replace the custom-cut, two-sided adhesive tape when you're done, it's otherwise pretty straightforward, and unchanged from previous models.
With the adhesive tape gone, we get our first peek at the hardware inside the Retina 5K iMac.
Let's take a look at the hardware that allows 14.7 million pixels with a resolution of 5120 x 2880 on a 27-inch display:
Texas Instruments NH245 8-Bit Dual-Supply Bus Transceiver
Texas Instruments BUF16821 Programmable Gamma-Voltage Generator and Vcom Calibrator
Parade Technologies DP665 LCD Timing Controller
Texas Instruments TPS65270 Monolithic Dual Synchronous Buck Regulator
Texas Instruments TPS65168 High Resolution Fully Programmable LCD Bias IC for TV
Barring the new display, the hardware inside the iMac Intel 27" Retina 5K Display looks much the same as last year's 27" iMac.
In fact, as we dive in deeper, we realize it is very nearly exactly the same.
And after following the guide to the letter, we've got our findings on the differences inside:
The Retina 5K's display data cable is slightly wider—to support those extra pixels.
Let's see what ICs this unsurprisingly familiar logic board is packing:
AMD Radeon R9 M290X GPU
Intel Core i5-4690 Processor
SK Hynix H5GC2H24BFR 256 MB GDDR5 SGRAM (256 MB x 8 modules = 2 GB total)
Delta Electronics 8904CF 143003
Intel DH82Z87 (Z87) Platform Controller Hub
Fairchild Semiconductor DE32GV
Front side of logic board:
Broadcom BCM5776 Gigabit Ethernet Controller
Cirrus Logic 4206BCNZ Audio Controller
Intel DSL5520 Thunderbolt 2 Controller
LMF4S1EH 5BBCIG 47A6HPW
Microchip Technology 1428-7 420BE5A BMY System Management Bus (SMBus) Temperature Sensor
Intersil ISL6327 Enhanced 6-Phase PWM Controller
This looks to be the exact same SanDisk PCIe SSD as the one found in the MacBook Pro 13" Retina Display Late 2013.
Unsurprisingly, we find the exact same ICs:
SanDisk 05131 016G 16 GB NAND Flash (four on each side, total of 8 x 16 GB = 128 GB)
SK Hynix H5TQ2G63DFR 2 GB DDR3 SDRAM
Marvell 88SS91383 PCIe SSD Controller
The AirPort/Bluetooth card, identified by its model number BCM94360CD, is exactly the same as the one we encountered in last year's iMac Intel 27 inch:
Broadcom BCM4360KML1G 5G WiFi 3-Stream 802.11ac Gigabit Transceiver
Skyworks SE5516 Dual-Band 802.11a/b/g/n/ac WLAN Front-End Module
Broadcom BCM20702 Single-Chip Bluetooth 4.0 HCI Solution with Bluetooth Low Energy (BLE) Support
iMac 27" Retina 5K Display Repairability Score: 5 out of 10 (10 is easiest to repair)
RAM is user-replaceable without opening the case, thanks to the rear access door.
You can still replace the hard drive and CPU inside this machine, albeit with some adhesive cutting.
Components are modular and fairly easy to remove.
The glass and LCD are fused together, and there are no more magnets holding the glass in place.
You'll have to masterfully peel off the old double-sided sticky tape and apply new tape in order to reseal this iMac into original condition.
44 comentários
Absolutely! Same procedure as last year's model: iMac Intel 27" EMC 2639 CPU Replacement.
Looks like you can upgrade to a new cpu (Haswell refresh probably) since it doesn't appear to be soldiered on
Thats unlikely, it depends on the mobo, i have not heard any confirmations of this so far.
Any idea what the part number is for the 8GB modules? This shows 4x2GB which is the standard. I ordered that memory configuration, expecting I can source new 8GB modules for less than Apple's price.
